Double Screen in Vivid
  • It would be interesting to have the double screen in Vivid, with Laucher 3 it was possible and it was very interesting.
    The cover map the direction when you circulate in Spain works the other way around instead of circulating upwards, circulating downwards, to see if you could look at it and that it would work correctly like any Navigator.
  • Как поменять на главном экране отображение карты на другое приложение, чтоб работало на территории России? К примеру Яндекс карты или Яндекс навигатор?
  • @Vadim S in order all we can understand each other....please use the English language for your posts
  • I barely understand your message. Vivid is under development....new features and bug corrections are constantly implemented.  There is a specific thread for vivid on xda-developers forum, where developers are active members
  • @Juan Perez double screen (split screen) is under investigating and testing for VIVID OS, play stay tuned. And the map northup but not heading up issue will be fixed in release on Nov.8
  • @Vi1 Gracias.
