toyota chr 2017 - Help Dasaita Max 10 problem
  • i finally got my backup cam working with dasaita max 10 in my toyota chr 2017 , i connected all the plugs from the head unit to my  car,  for the oem cam i had to pull a wire from the backup light to make the cam work.
    now i have another problem on the car screen,  i get a view warning message comming up EPB shift interlock function Activated,Drive start Control Malfunction, Egine Coolant Temperature High stop in save location.
    these warnings keep coming back when i connected the dasaita max 10
    So i removed the Dasatia Max 10 en replaced it with the oem radio gues  what everything works fine again..
    is there something i am doing wrong ?
  • Hi, cleo cleonise
    Pls reply us ASAP, thanks.
  • There still some problem with wifi.
