Hello. As in the topic. Is there such a possibility and how to do it? And what are the orists or the problems associated with it? Thank you all for your help
Thank you for your reply and help. I have information that you still need to hold off on switching to Android 11. But as soon as it is possible with a nice pleasure to do it. Because you can see that VIVID is also already on Android 11
I am interested in the image file with steps to upgrade VIVID Android 10 to VIVID Android 11. I upgraded from MAX10 PX6 to VIVID btw, would that be a problem?
@Quick Yuan Would you be so kind to provide the download link for the MAX11 (PX6) .img file? I'm willing to take the risk to upgrade my MAX10 unit, even if there's a chance of bricking my unit. I know it will be my own fault if it fails, so you won't hear me complain if it fails. Thanks a ton! ;-)
@Fahad The problem of wifi off is probably more related to the configuraion of Zlink rather than any Firmware issue (and of course Android version, which i dont recommend you to upgrade, as there is no new features or better performance than Android 10 based Rom)
by default Zlink is configured as "backgroud connection enabled". This is ....while Zlinnk is loaded in memory (recent apps) it will try to connect wirelessly to the device (android auto or Carplay). For that wireless connection Zlink forces to disable the WIFI connection of the unit and Enables the Sharing Intenert Connection by WIFI.
So, go to Zlink with the bluetooth of your phone disabled (to prevent instant connection) and, on the Welcome Zlink Screen go to settings....there disable the Background connection.
By this....connection only could occur when you put Zlink as active app.
If Zlink is on background and you enable your Wifi...it will not disconnect anymore
Hello. For your information, it doesn't support to update the later system MAX11(Android11) from MAX10(Android10). We recommend not to do the mandatory installation for another different system to avoid the potential damage to the machine or results in bricked unit.
