I have had a PX6 for around 18 months, is it possible to update? Similar to how a mobile phone has regular updates? Thank you.
@Mark Wesson Hi there, if there is no malfunction of your system, we don't suggest any update, your understanding will be appreciated.
@Support Dasaita I do find it strange there are no regular upates like a mobile phone has! Thanks.
@Mark Wesson
telenav_vivid_rk3399_11.0_ota(20230617)
https://www.dropbox.com/s/htoa38vxybhs3es/rk3399_11.0_vivi_20230617%E5%8D%87%E7%BA%A7%E5%8C%85.rar?dl=0
A video tutorial:
- Please download the document via your computer/laptop, then use the WinZip application to unzip the file.
- Please make sure to format the USB drive(FAT32 Format)/SD card before copying the update file to it.
- Please ONLY put Update.zip file in the root directory of the USB drive/SD card.
- Please note that all data on this unit needs to be wiped before updating the system, so back up important data if necessary.
- Finally click the Settings > System > System updates to start the update
So I am ok to update to this?
Will I lose my apps and settings etc? Thanks
@Mark Wesson Please go to the canbus settings page and choose option 10 after the update.
@Support Dasaita So if I update, will I loose my settings, apps etc? Thanks.
@Mark Wesson We would like to tell you that you have to wipe the data before update, so you will lost the settings and apps etc. If you still want to make an update, please refer to the procedure above.
