@Support Dasaita what time zone? The factory one?
@Support Dasaita ok I did all the resetting and now I'm back to the car play activation . Is there a code that I can manually enter because it's still needs to be activated
@Joshua Hall Have you go to Settings > Date & Time to reset the time zone yet, and then change a hotspot but nu luck ?
@Support Dasaita I have done all of that and nothing has worked!
@Joshua Hall Please kindly take a video to demonstrate the procedure that you mentioned, we would like to forward the software engineer to check. Your cooperation will be appreciated.
@Support Dasaita it won't let me up load the video but I put the time zone back to China and put the system on a different WiFi still nothing
@Support Dasaita never mind it finally just worked I appreciate all the help
@Joshua Hall We are glad to know that your problem finally got fixed, would you kindly leave a review of the head unit you bought which will be highly appreciated.
Here is the listing of it.
https://www.amazon.com/dp/B0CYZX1ZM4
@Support Dasaita carplay doesn't work and now my head unit is operating in vivid instead of scout. Do you have a fix for this
Please go to Settings > About machine and send us a screenshot about the current Build Number and MCU version. @Joshua Hall
