Super loud buzzing instead of ringtone on incoming call
  • Dasaita 10.2 Android 11 Car Stereo for Toyota Camry 2012-14
    When I first installed it, I'd hear a normal ringtone coming through my car speakers when I received a call to my Bluetooth-paired phone.
    I've changed phones a couple of times since then. Currently, I have a Pixel 6a. When I get a call, the Dasaita plays a super-loud - I mean, volume at 11 - buzzing noise instead of a ringtone. Everything else about the call is normal.
    I recently did a factory reset of the Dasaita to clear some other issues, but I'm still getting an ear-splitting buzz instead of a ringtone.
    Any ideas on what to do?
  • @Ed InSac We would like to tell you that the volume is controlled not only by our head unit but your phone as well. Please make sure that volume on your phone is suitable and then go to Settings > Car > Factory settings > enter 126 > Voice and adjust the sound of BT to be an average level. Your cooperation will be appreciated.
  • The volume level has been adjusted and it's fine. The tone for an incoming call is still a buzz, like the buzzing you can hear on AM radio, rather than a ringtone. Any further advice to solve this would be appreciated.
  • @Ed InSac Please let us know your order number and the following information so that we could better locate and give you more appropriate instruction.
    1. Go to Settings > About machine and send us screenshot of the current Build Number.
    2. Go to Settings > About machine and send us screenshot of the current MCU version
  • Try downloading new ringtones at the website: https://dzwonkipl.com/
  • I also had the problem of incorrect sound when receiving calls and solved the problem by downloading a new ringtone and resetting. You can try the same by going to songringtone.net to download a new ringtone and adjust the sound settings. Hope this helps!
  • Try these steps:
    - Update the Dasaita firmware.
    - Check the audio settings on the Pixel 6a and Dasaita.
    - Delete the Bluetooth connection and pair again.
    - Check the ringtone settings on the Dasaita.
    - Adjust the volume or check for electrical interference.
    If that doesn't work, visit tonuri de apel to download and reinstall the ringtone
  • @james selenla
    Hi James,
    If the issue still exist?
    Could you please send a video of showing this issue?So that we could better confirm.
  • This is the website where I download free ringtones for my phone:https://efektydzwiekowe.com/
  • If your phone makes a super loud buzzing sound instead of a ringtone on incoming calls, try checking your sound and ringtone settings. The ringtone file might be corrupted or incompatible. You should switch to another ringtone, update your system software, or restart the device. In many cases, deleting the faulty ringtone and downloading it again can solve the issue.
