@Support Dasaita I bought the G12 from Dasaita's store with ORDER Number: SP-DA4613. It's for a Honda HRV 2016, EU model, manual without OEM camera.
@john bogianou
Could you please follow these steps to help us diagnose the issue with your steering wheel buttons:
- Go to Settings > Car > Factory Settings and enter "logcan".
- Press the steering wheel buttons that are not working properly about three times. You should see codes appear on the screen.
- After completing this process, go to Filebrowser and copy the log file for us.
- Please record a video showing the entire process and send it to us along with the log file. We will forward these to the manufacturer for further diagnosis. Your cooperation is greatly appreciated.
@Support Dasaita I switched A to wire A1 from wire A2 and the steering wheel buttons all work as intended. The Car Control Settings App is still unmodifable but this feature is not important to me. Thank you for your support.
@john bogianou We are wondering if the cable that you are using is the CB015, if you still want to get the Control Settings App work, it will be helpful if you could logcan for us. Your cooperation will be appreciated. You could change the Control Settings in through steering control and our engineer will receive the code and diagnose accordingly.
@Support Dasaita I have the CB015 harness. I switched the D1 to D2 wires (sorry for the confusion).
@Support Dasaita https://www.youtube.com/watch?v=EdNoE6Quk1g
I send the log file to your support email
@john bogianou this video is inaccessible, could you check again.
@Support Dasaita I think that is now accessible
Hi, so I am having a issue as the car control app does not work on my PX6 radio for my 2014 Honda Accord EX-L. I have been reading some of the post in the forum and I have the A to A2 on the radio. My order number is Order SP-DA3985. I have tried to factory reset the radio and still no success. Also my steering wheel buttons does not work for my call setting and hanging up the calls.
@Kapil Patel
We are wondering if you could try install the following APK: https://www.dropbox.com/scl/fi/y6bwkdf5iswzjv6s1fjo1/HCTCanBus_px6_11.0.apk?rlkey=ua1gc3b9kqv381cabc1p1l5bl&dl=0
Please download the APK and then go to the APKInstaller to install it.
I tried to install it and I am getting a parsing issue.
There is a system update available I can run the update if needed.
@Kapil Patel Please download again through the link below and check if it could update successfully.
If still no luck, we are wondering if you could record a video to demonstrate your issue. Your cooperation will be appreciated.
How can I attach video. I am still having same issue with the apk file for android 11 and it is saying parsing
When I get a chance im going to try and update the radio to android 12 and see if I can use the apk files you have sent to see if it will work.
@Kapil Patel Android 11 could not be updated to Android 12. As to your issue, we are wondering if just the call setting and hanging up the calls could not work or other control Settings features could not be adjusted.
If just the call buttons, you may need to replace the cable, if the Control Settings, we will reflected the engineer for further assistance.
