@Support Dasaita I'm not exactly sure what you mean. First, which update should I use for my unit? If we can determine that choice then I'll try it and take pictures of the error if it has one.
waze does not work in the widget
@Randy T Please let us know your order number and then go to Settings > About Machine and send us a screenshot of the current Build Number and MCU version. Only in this way, we will determine which update file that you could use for upgrade. Your cooperation and understanding will be appreciated.
@Junior Cedeño Please go to Settings > About Machine and send us a screenshot of the current Build Number and MCU version, we will check if your version could support waze on the left widget.
@Support Dasaita Order # 111-1325500-3510600
@Randy T Here is the version that you need to update.
HA3_rk3399_10.0_ota(20230803)
@Support Dasaita that update did it. However, I was really hoping for an Android 11 update. Do you have anything like that planned?
@Randy T Sorry that if you want Android 11, which means that the system need to be flashed. There will be risk, so normally, we won't recommend to do that.
@Support Dasaita do you have any options to use Zlink for Android Auto/Carplay on this unit instead of Carbit?
Just updated vivid11 px6 firmware, update went smooth, but now CarPlay and multiple other apps won't open
figured my issue out with carplay. seems like zlink didnt get installed, found the 4.29 apk and installed it. once loaded i was greeted with the activation screen and all i had to do was connect to a wifi to get it fully loaded
I noticed after installing the update zst27_sc138_12_(20240513) on QCM6125 the LOUD option under the Amplifier does not do anything at all anymore... even if i raise the two bars all the way up.
@Randy T Your head unit has the Android Auto/Carplay, you could go to Factory Settings > enter 126 > enable zlink
@ZAKI KADOURA Could you send a video of the situation that you mentioned, we have tried to replicate your issue but no luck on our head unit? Await for your prompt reply.
Bonjour,
Copie d'écran de ma version
Puis je mettre à jour la dernière version
@Support Dasaita all audio functions are not working except for the BASS one. The others don'tdo any change no matter what i select... I sent the video to office@dasaita.com
Just a note... I did a clean installation of the update... selected to delete everything and start some scratch
UPDATE: I did a system reboot and all are working fine now... sorry for the trouble this may have caused.
@Jean-Pierre LOTHAIRE Your version is not the latest one, our latest firmware is 20240513 now, please update the system to the latest, note to wipe all the data before update. In the meanwhile. You could further demonstrate your issue, as we have not heard from you since March.
Now I have max since waze doesn't work in vivid but I want vivid with waze
@Mike Cast
Could you test if waze works well in vivid 11 please?
