Steering wheel setting(with Canbus, note that it will work when the Canbus option has been chosen correctly, if no luck, you could try the steps below):
1) Please go to Settings > Car > Factory settings > Others > Steering wheel keys assign > CAN Key > Apply > Exit (Reboot).
2) Please go to Settings > Car > Steering Wheel Keys and start to program or go to Home Menu > Wheelkey Study app and start to program.
You could also refer to the video.
https://www.dropbox.com/scl/fi/p3togks62ddt49706zs4f/2241.mp4?rlkey=i0xdd8ugy3ako4uk7w0gk7rf9&dl=0
Steering wheel setting(without Canbus, a must step if your model does not have the Canbus box):
1) Please go to Settings > Car > Factory settings > Others > Steering wheel keys assign > SWC Key > Apply > Exit (Reboot).
https://www.dropbox.com/scl/fi/ykiclryuzwmf2bf6bbg1k/Video-Steering-wheel-keys-assign-SWC-Key.mp4?rlkey=hwm530vzvtcj5tb2tyr28g5n6&st=qhmx5ffp&dl=0
Hi, I have a Canbus installed however the go forrward to a new saved music on spotify it backwords, when I press forward it goes back and when I hit back it goes forward... how can I edit this or is there a different way to do it mually...
I have a G13 on a Tundra 2018
any help would be greatly appreciated....
JJM
I need assistance I have two issues :1) I'm not able to use my steering wheel "voice button "to make calls, example " call home" . 2) I can access the contacts list in the V13 via the steering wheel controls select the persons name and select the number but it will not make the call. . I can select the number via touch screen and it will make the call. I had my wife call me back on her cell and I can recieve the call with no problems.
This is what I have: 2015 Toyota Tacoma, Vivid 13 system QMC6125 Build# QMC6125 13 stoa_123eng.hct 20251111.140008 na-v2.1, MCU MTCH_HA4Z_V4.16f_1 June 30 2025 16:20:57
Sim card works and have phone line attached system sees. In the system settings I ensured the phone number uses my carriers service and when unavailable use wifi. No problems with surfing or any applications.
I followed the instructions for steerring wheel services:
