How to start Wheelkey study
  • Steering wheel setting(with Canbus, note that it will work when the Canbus option has been chosen correctly, if no luck, you could try the steps below):
    Steering wheel setting(without Canbus, a must step if your model does not have the Canbus box):
    1) Please go to Settings > Car > Factory settings > Others > Steering wheel keys assign > SWC Key > Apply > Exit (Reboot).
    2) Please go to Settings > Car > Steering Wheel Keys and start to program or go to Home Menu > Wheelkey Study app and start to program.
    You could also refer to the video.
    https://www.dropbox.com/scl/fi/ykiclryuzwmf2bf6bbg1k/Video-Steering-wheel-keys-assign-SWC-Key.mp4?rlkey=hwm530vzvtcj5tb2tyr28g5n6&st=qhmx5ffp&dl=0
  • Hi, I have a Canbus installed however the go forrward to a new saved music on spotify it backwords, when I press forward it goes back and when I hit back it goes forward... how can I edit this or is there a different way to do it mually...
    I have a G13 on a Tundra 2018
    any help would be greatly appreciated....
    JJM
  • @Juan Martinez
    Please go to Settings>Car >Factory Settings>126>CANBUS>SWAP> Swap/Normal>Save>Reboot
  • I need assistance  I have two issues :1) I'm not able to use my steering wheel "voice button "to make calls, example " call home" . 2) I can access the contacts list in the V13 via the steering wheel controls select the persons name and  select the number but it will not make the call. .  I can select the number via touch screen and it will make the call.  I had my wife call me back on her cell and I can recieve the call with no problems.
    This is what I have: 2015 Toyota Tacoma, Vivid 13 system QMC6125 Build# QMC6125 13 stoa_123eng.hct 20251111.140008 na-v2.1, MCU MTCH_HA4Z_V4.16f_1 June 30 2025 16:20:57
    Sim card works and have phone line attached system sees. In the system settings I ensured the phone number uses my carriers service and when unavailable use wifi. No problems with surfing or any  applications.
    I followed the instructions for steerring wheel services:
    1) Please go to Settings > Car > Factory settings > Others > Steering wheel keys assign > CAN Key > Apply > Exit (Reboot).
  • @Richard Kesterson
    Thanks for your contact.
    Could you please tell me if there is any response when the voice button is pressed? Can the voice assistant be awakened?
    To better confrim the current version,please go to Settings > About machine and send us a screenshot about the current Build Number and MCU version.
