No sound from CarPlay navigation or Siri reading messages.
  • 2014 Toyota tundra limited. In carplay Siri will not read messages, music is muted and the Siri logo moves like it should be talking but no sound. Also Apple Maps on CarPlay voice navigation is not working. Turned on but no sound. Any help would be great.
  • I as well. G12 purchased in March in a 2014 Tundra SR5 w/o JBL. I assume it has to do with an Apple update, but before I contacted customer support I figured I'd look in here first.
  • @William Schofield   Are you having the same issues with yours?
  • Make sure "Do Not Disturb" is off in the Android settings on the unit. I believe it is in the applications settings and scroll down to find it. I had the same problem with all the prompts from carplay being muted, and this was the fix.
  • @Chris Justice Yes, mutes sound, Siri logo animates, but does not read the message out loud.
  • @William Schofield   Well I got aggravated and did a factory reset. Which sucks cause I have to set everything back up. Well Siri now works!  BUT before I had Hulu on there, now I don't and says Hulu can't be loaded on device. Haha.
  • Glad I'm not the only one with this issue. Did a factory reset and it seemed to fix it but scared to customize it again and install any additional apps. Any luck for you guys?
  • Well I checked the "Do Not Disturb" and that was off thank you@Thomas T  and did the factory reset and we're good again, thank you@Chris Justice
  • @Hayden Guild   I know man I'm with you. This unit seems very touchy to change. Now that Siri is there the volume is very low. I need to figure out how to turn her up some.
