Zlink son distorsion et lag (update zlink)
  • Bonjour ,
    J'ai un autoradio dasaita Android12 autoradio pour Toyota RAV4 2019 2020 2021 2022 sans fil Carplay et Android Auto autoradio | Qualcomm 665 | 12.3". Mon zlink carplay fonctionne mais par rapport au son de la musique il y a une distorsion. Le son est en retard. C'est la version 5.4.50. Je voulais savoir s'il y avait une autre mise à jour pour zlink. Merci d'avance.
  • @Mohammadou Mahdyou L Cissé
    Regret to tell you about now there is no new Zlink.
    If we release it later, we will let you know.
    Based on your provided picture, we notice that your MCU is not the new version.
    If possible, we suggest that you can try to update it firstly.
    G12 MCU-4.12:
    Please download above update file via your computer/laptop.
    Please make sure to format USB drive(FAT32 Format) before copying file to it.
    Please ONLY put “hmcu.img” file to the root directory of USB drive.
    Please note that all data on this unit needs to be wiped before updating the system, so back up important data if necessary.
    5.
    Finally, click the Settings > System > MCU updates to start the update.
  • Hello dasaita,
    thanks a lot i will install them & i will tell you if it is good ^^
    You are welcome, dear friend.
    For any problems, please do not hesitate to let us know.
    We would like to assist you and we aim to ensure a better user experience going forward.
  • Good morning,
    for zlink it still persists. Finally, for my calls when I try to answer by zlink carplay no one hears me when I speak with the internal microphone. While I can clearly hear the person speaking on the phone. What solutions do you have for this?
    Here is the version of my car radio and its characteristics:
    We are wondering whether you finished other update except MCU-4.12 that we have sent you.
    In your new picture, its Android version is different from the previous one.
    Besides, please provide us with your Order Number so as to locate the exact model&version you purchased.
  • @Support Dasaita hello,
    i buy them in amazon usa. It's the version of Dasaita Android 13 Car Stereo for Toyota RAV4 2019 2020 2021 2022 with Wireless Carplay & Android Auto, 12.3" Touch Screen Head Unit, GPS Radio, 8G RAM 256G ROM, Bluetooth 5.0, 5G WiFi, 4G LTE. https://www.amazon.com/dp/B0CP7BRBSS?ref=ppx_yo2ov_dt_b_fed_asin_title
    The number of the order in amazon is Order # 114-2459070-6506636
    Thanks for your reply.
    Upon checking, Order#114-2459070-6506636 you purchased HA5901-G12(Android12), its system information matches the picture you sent on 2024-7-31.
    However, we notice the new picture is Android13, which is different from the provious one.
    We are wondering whether you have tried to do other updates except MCU-4.12 that we have sent you.
    Please confirm with us.
  • Hi,
    Oh yeah that's it. yes I tried another update because zlink carplay did not work well both for calls and for music which causes distortions and lags. That's why.
    Could you please tell us where you obtain the update file?
  • It's malaysk rom (https://xdaforums.com/t/rom-qcm6125-s-12-0-13-0-malaysk-rom-qcm6125-mcu-mtch-hctgq-android-12-13.4650179/post-89292315) but between this update file the old update i have for my unit car they have the same problem ^^
    Usually, we don't recommend to do the mandatory installation for other Android system because it will cause the potential damage to the machine.
    Please try to revert back to the original Android system with the latest firmware..
    System Firmware-G12-20240812:
    https://www.dropbox.com/scl/fi/xgeqo49jd33fzxvab92k5/update.zip?rlkey=348xdnr3e0ugks99in8y9rdgm&dl=0
    Specific Operation:
    Step1.
    Step2.
    Step3.
    Step4.
    Step5.
    Reference operation video:
    okay i will do it. and i want to know what is the different between my G12 and https://www.amazon.com/dp/B0CP7BRBSS?ref=ppx_yo2ov_dt_b_fed_asin_title
    Or there are a few difference?
    Both items are the same model HA5901, but different Android System.
    You purchased G12, the link is G13.
    Please refer to the photo.
  • @Support Dasaita Hello,
    I did the update with wipping all file.  (System Firmware-G12-20240812). The lag and distortion problem is resolved. On the other hand, the external microphone doesn't always work 😐. Steering Wheel Buttons for Next and Previous are crossed...
    Thank you for your time and patience in this matter.
    For the issue of the steering wheel buttons are crossed,here is the way to get this problem resolved:
    settings> car> factory setting (password :126)> canbus > swap key
    For the external microphone,could you please try to unplug the external mic to see if the problem disappeared?because there is also a built-in mic on the unit.
    We 'd be appreciated you could provide more details to our email to learn more ,like video to our emails: support@dasaita.com
    Thanks.
  • Ok I will do it and I will get back to you later. On the other hand, if I want the information relating to air conditioning to be displayed in my car radio. What to do? Because it is not displayed on it
  • @Mohammadou Mahdyou L Cissé If your original car's AC information display on the small screen?
  • @Support Dasaita No original car's AC information don't display on the small screen
  • @Mohammadou Mahdyou L Cissé Hi, where is your original car's AC information display before?
  • 1 / 2
  • 2
