I got an Android13 Car Stereo
@Andrew Casem
In order to learn your current version information,
please go Settings > About Machine,
then provide the following pictures: Model; Android Version; Build Number; MCU version.
Thanks for your time & cooperation in this matter.
Model: QCM6125
Android Version: 13
Build Number: QCM6125 13 S10A_123 eng.hct.20240614.021346 NA
MCU version: MTCHS_ZST_V4_12d_1 May 22 2024 15:53:23
@Andrew Casem
Thanks for getting to us.
Regarding to your issue, we suggest that you can try to update the latest firmware firstly.
Update File-G13(20240708): https://www.dropbox.com/scl/fi/goq8klvvad3qrea47a2sl/update.zip?rlkey=ichz4hwfkb5o5f1byssjub83j&dl=0
Specific Operation:
Step1.
Step2.
Step3.
Step4.
Step5.
@Support Dasaita I think that unit is not a Dasaita one. (ZST mcu label does not belong to Dasaita, AFAIK)
@Iker Gomez why would I ask for support for a unit that isn't Dasaita?
https://www.dasaita.com/products/dasaita-android13-car-stereo-for-toyota-tundra-sequoia-2007-2022-wireless-carplay-android-auto-car-radio-qualcomm-665-10-2-qled-screen-wifi-4g-lte-6g-8g-64g-256g-dts-gps-navigation-head-unit-optical-output?variant=44088339431642
@Support Dasaita I installed the file - I will drive around the next few days and will let you know. Thanks for the quick response!
@Andrew Casem
You are welcome, dear Andrew.
Please feel free to get in touch if you need further help.
We remain at your service :)
@Andrew Casem I am.not saying that. I am saying that MCU does not correspond with dasaita but with other manufacturer that mounts the same platform. @Support Dasaita ??
