I set it to Japan 2 in the settings, but when the radio tuning is set to the front, it doesn't show anything below 87.5.
There are a variety of preset icons, some with frequencies set and some without. How can I display and delete these icons?
Maybe there's a hidden menu for more advanced settings?
@osamu nonaka
Hello ,
May we know how do you get this vivid12 OS?
We found that your order is G13,the correct OS is the below:
Hello, this is an app that came pre-installed on my G13. Android 12 is installed.
After updating the firmware, the above screen appeared, but the radio still did not display below 87.5MHz.
@osamu nonaka Please be informed that the FM radio frequency on our G13 supports a range from 87.5 MHz to 108 MHz. This means that the radio will not display or tune frequencies below 87.5 MHz, as it is outside the supported range.
As to the delete of the preinstalled station, here is the link of how to cancel them.
https://www.dropbox.com/scl/fi/fr6gfbn8lro39010pjnzn/vivid.mp4?rlkey=d4nrvrcyhqlp2wh07x8lggs0q&dl=0
I can tune into Japanese frequencies, but I can't register them in the memory.
@osamu nonaka
If you're referring to save the radio station ,please click here.
