G13 unit SIM card issue in a Toyota Auris
    I wanted to know if it is possible to somehow enable (or have you implement) the functions I have specified in the subject.
    I recently installed a G13 unit in a Toyota Auris and connected a SIM card. As I am not going to use Android Auto or Carplay, the internet connection is provided by the SIM card.
    On one hand, I am interested in enabling a lock screen. Enabling this in security makes, for example, that you can put PIN to some apps like Whatsapp, among others, to lock them, since if there is no screen lock system enabled, the option to set a PIN to WhatsApp is not shown in your settings. Also, are you planning to release any fingerprint reader for unlocking with biometrics via USB?
    On the other hand, and this is perhaps more important, I can't find any option to disable the PIN request for the SIM card. The latter is very important, because if the vehicle is stolen, until you enter the PIN when it is enabled, there is no internet connection, which makes you unable to use Google's "Find my device" functionality.
    I would like to know, by the way, where I can download the MCU updates for my unit, as I can't find them around the forum.
    Regards.
  • @JoMaRS
    Hello customer,
    G13 version doesn't support to set the lock screen .
    Regarding to the SIM card of PIN, the unit can't support to enter and remove the pin directly .Please try to set it on your phone firstly .
    We also send a message to your email via this e-address: team@dasaita.com, please check it.
    Thank you for your time.
    The option you have suggested to me removes the PIN request, but only on the device where that option is configured , that is, that same SIM card when put in another device, if that device does not have the option to remove the PIN request, it will continue to have SIM Lock activated.
    I want to make a recommendation to the development team to include this option in future updates or, if the option is hidden, to show it in the settings. Please keep this request in mind.
    Thank you.
  • @Support Dasaita Mi inserisco in questa discussione per dirti che questa mancanza di possibilità di protezione della sicurezza e privacy è un gravissimo limite del device che, conoscendolo, mai mi farebbe acquistare tale versione. Sono deluso😕
  • Grazie mille per il suggerimento, faremo sapere al nostro supporto tecnico nella speranza di apportare un miglioramento per i prodotti di nuova generazione.
    Se stai utilizzando la nostra unità vivid version, potresti impostare la schermata di blocco su Protect.
    Grazie per la comprensione.
  • Could you simply add the "Valet lock" function of Vivid 13 in G13. Please communicate this to the appropriate department so that they can implement it in a future update. It's not a whim, as Gennaro says, it's a serious lack of security and privacy issue. When you have the device running on a SIM, it's a no brainer that the mechanic, car cleaning worker, etc, can access your conversations. It is an issue that should take priority.
  • @JoMaRS
    Thank you for your kind reply. Of course we will forward to our related department, adding the function is a project for G13 ,and we need to constantly test whether the firmware will run smoothly due to data changes. Hope you could understand.
  • @Support Dasaita Of course we understand that, but please understand that there are priorities, such as this one, which is a security and privacy issue, for example, as well as other elements for the full functionality of the product as purchased by customers, such as the operation of the external microphone and other issues that have been unresolved for some time.
  • @JoMaRS
    Thank you for your understanding.
    We will try to release the new firmware as soon as possible.We also hope our vivid version will be a great experience for you.
    We'd be appreciated that if you could let us know how you like our customer service in your purchase,. Your comment really matters and helps to keep us motivated.
    Thank you for your time so much.
  • how to remove emergency lock for my radioG13
  • @Rasheed Rahaman
    Our head unit has no built-in password or PIN code setting by default.
    The PIN lock is most likely enabled via your Google account.
    Please log out of your Google account, clear the login data, and do not set up a security PIN when you log in again.
    Thanks for your time!
