In my mazda CX5 / MAX10 Version doesn't work over Bluetooth your image HA3_rk3399_10.0_ota(20230803)
@Martin Niebur
For further confirmation, please tell us whether CarPlay cannot work after updating the firmware by yourself.
Thanks in advance.
@Martin Niebur
If YES, please try to revert back to the previous firmware.
MAX10 Version(20230302):
https://www.dropbox.com/scl/fi/mwzw2q4ojdfoz3mnp0i08/update.zip?rlkey=np70fog84q4mmy903xsofdz13&st=znaujgwo&dl=0
I want to connect Carplay via Zlink as described by you. The error is I select your radio under Carplay on the iPhone and it tries to connect, unfortunately without success. It stops and says device not found.
@Support Dasaita MAX10 Version(20230302) its an very old firmware.
@Martin Niebur
Please try to do as follows to see how it goes:
Settings > System > Reset Options > Erase all date(factory reset).
The older firmware works. For security reasons, I would like to use the current one with a working ZLink
@Martin Niebur
If MAX10(20230803) firmware cannot work for Zlink, we suggest that you can try to update MAX10(20230302).
How do I update the Android system for the Max10?
@Martin Niebur
Please check the update tutorial below:
