Carplay(zlink) microphone problem
  • @Aaron Valdez I am even using the usb port in the Tundra that I previously used for carplay.
  • @Aaron Valdez
    Can the device recognize files on a USB drive?
    If you use Safari ,please go to Safari>Settings>General> and uncheck 'open safe files after downloading on computer
  • Yes I installed on the usb drive and when I plug it into the truck I get the screen to pop up to say install. The problem is the install fails.
  • Install fail
  • @Aaron Valdez
    Could you provide a video of showing the issue to this email ?
    team@dasaita.com
  • @Aaron Valdez
    In order to arrange the personnel to follow up on your issues better,
    please provide us with your Order Number & Purchase Date.
    To further confirm, please go Settings > About Machine,
  • @Support Dasaita I was able to get the firmware update and MCU update to work. I had to pull the head unit and use the other USB to get it to work. I made a few test calls and unfortunately ONLY the internal mic is working still. I tried unplugging and replugging in the external mic, but nothing!! I have checked 10 times and it's plugged into the mic port at the back of the unit and the mic headphone jack is plugged into too. I think something is seriously wrong with the unit. Should I return it?
  • 1
  • 2 / 2
