Carplay(zlink) microphone problem
  • @Aaron Valdez I am even using the usb port in the Tundra that I previously used for carplay.
  • @Aaron Valdez
    Can the device recognize files on a USB drive?
    If you use Safari ,please go to Safari>Settings>General> and uncheck 'open safe files after downloading on computer
  • Yes I installed on the usb drive and when I plug it into the truck I get the screen to pop up to say install. The problem is the install fails.
  • Install fail
  • @Aaron Valdez
    Could you provide a video of showing the issue to this email ?
    team@dasaita.com
  • @Aaron Valdez
    In order to arrange the personnel to follow up on your issues better,
    please provide us with your Order Number & Purchase Date.
    To further confirm, please go Settings > About Machine,
  • @Support Dasaita I was able to get the firmware update and MCU update to work. I had to pull the head unit and use the other USB to get it to work. I made a few test calls and unfortunately ONLY the internal mic is working still. I tried unplugging and replugging in the external mic, but nothing!! I have checked 10 times and it's plugged into the mic port at the back of the unit and the mic headphone jack is plugged into too. I think something is seriously wrong with the unit. Should I return it?
  • @Aaron Valdez
    We just released a new firmware to improve the microphone.
    If possible, please try to update it to see how it goes.
    System Firmware-G13-20251030:
    https://www.dropbox.com/scl/fi/z47cujybwxdgj15bokfbz/update.zip?rlkey=cbh8x18aszp1vj9pso77u154e&dl=0
    In order to record your issue and better follow up, please provide us with your Order Number & Purchase Date.
  • Unfortunately that did fix turn on the external mic. The internal mic works which is located on the lower left side of the touchscreen, but the external mic that is plugged in correctly in the back does NOT work at all. I am growing tired of this and the amount time spent getting get this to work on calls. If this is something I am doing wrong, let me know!!
  • @Aaron Valdez
    In order to arrange the personnel to follow up on your issue better,
    please provide the following information:
  • Multiple times I'm tired of I provided an order number and purchase Date and all the information four or five times.
  • 1
  • 2 / 2
