G12 Random Reboots
  • Dear DASAITA, after installing the version 20241126 there are random reboots of the device. During the period of operation, the only app that worked was the default radio. I hope you can give me support because it is really annoying to see the device rebooting during its normal operation.
    It is also worth mentioning that I have also made two clean installations of the mentioned firmware, always obtaining the same result. Random reboots
    The MCU version is MTCH_HA4Z_V4.12b_1
    Thank you in advance for the support you will give me
  • @Antonio Catalano
    Thanks for your message.
    We are wondering if you know the firmware version before updating.
    Could you please confirm with us?
    Besides, please provide the following picture:
    Settings > About Machine > Build Number; MCU version.
    Regarding to your issue, we suggest that you can firstly try to use a Pin/Paperclip to press and hold the RST Button for 15 seconds to enter the recovery interface to do the factory reset.
  • @Support Dasaita Before issuing the alert I have carried out the following tests. Using USB KEY updated (firmware G12 20241126) with Wipe data/factory reset with Android system online and finished installation process, I installed some apps (TOMTOM Amigo, NAVRADIO+). Tested during normal driving. The device has been randomly reactivated. Performed another test by reinstalling the firmware version entering recovery and carried out Wipe data/factory reset and subsequent restart of the device. Performed a new reset and installed the same G12 20241126 firmware using the "Apply update from SD Card or Usb" function. With this test I left only and exclusively all the system apps and used only the default radio. After a few days of testing I had equally random reboots. I remain waiting for resolution of this boring anomaly. Thanks
    P.S. My last firmware before update was G12 20240914
  • @Antonio Catalano
    Please try to revert back to the last firmware to see how it goes.
    System Firmware-G12-20240914:
    https://www.dropbox.com/scl/fi/uirobdiwmfitdaft4ls33/update.zip?rlkey=kss0w0qtm9elt4wsq4bnkfhn2&dl=0
  • @Antonio Catalano Same issue.
    Went on 2 hr drive this weekend between 2 states, no issue with reboots.
    Went on a 5 minute drive this morning to work, randomly reboots lol.
    This issue is so inconsistent and random for me, it's difficult to replicate or record to show the Dasaita tech team. I don't know what to make of this issue.
  • @B C
  • @Support Dasaita please refer to my initial post addressing the same issue.
    https://www.dasaita.com/community/forum/topic/143751/random-rebooting-while-driving#post-327889
  • @B C
    We have sent the corresponding update file in the following post.
    Please refer to the tutorial and try to do the update.
  • @B C I wanted to ask you something. Did you install the SIM module on your G12? I think that’s the problem with reboots. The problem has appeared to me since I physically connected the module. I have now physically disconnected it and am conducting some tests. For now and only for now, I have not had any reboots but I need to conduct the test in several days. I await your reply. Thank you
  • @Antonio Catalano
    Hello
    Thank you so much for sharing this information.
  • @Antonio Catalano , I have a G12 installed in a 4Runner and have been seeing what sounds like similar issues since the install.  I've done the upgraded MCU, firmware, etc - still unusual stability pattern.
    Your note seems really helpful - had not considered I also have the SIM module plugged in (no card though for me).  Before I consider ripping the dash apart to unplug it, are you able to kindly confirm if you are still seeing improvement with the SIM module removed?
    Thx in advance.
  • @Antonio Catalano Hello. I apologize for the late reply, as I don't receive notifications unless I log back onto the forum.
    I actually didn't install the sim module, as I knew I would either be using bluetooth or my phone as a hotspot, so I had no need for it, data-wise. I haven't had the chance to install the latest firmware that dasaita sent, since my initial install failed (possibly due to installing both the mcu and firmware at the same time. The mcu installed, so I'll try it again separately since the automatic firmware update app doesn't have the latest firmware sent to us to install OTA).
  • @The Great Donkey Hello. I’m still in the testing phase but since removing the SIM module I have not had restarts. Given that they are completely random restarts, I think more time is needed. Since my last message, to better test the G12, I installed some apps (Tomtom Amigo, Dab-z) that I use simultaneously.
  • @B C ok Thanks. To update the firmware, do this test. If you unzip it, you'll find a 2024.11.26 folder, and inside it the correct Update.zip file. I just upgraded my G12 and everything seems ok😉
  • Greetings to the community. After two months of removing the SIM module I have not had reboots. The test was conducted on short (within 30 km) and medium distances (between 30-150 km) with continuous operation using navigation software (TOMTOM AMIGO) and radio (DAB-Z). I have not observed any anomalies. It remains to be tested over long distances (150-1000Km). As soon as I have done the last test, I will report on this. Firmware installed G12 20241126. That’s about it, for now.
  • @Antonio Catalano
    Thank you for your update so much
  • @Antonio Catalano
    Very helpful update.  Thank you for sharing your progress.
  • Hello, continuing what I wrote above, I have carried out tests in the long distance. Distance covered 1100 Km, 10h of operation (5h of continuous operation before stop restorative and additional 5h to completion of the trip). Test performed using TOMTOM AMIGO, DAB-Z, connected Smartphone and active Wireless connection. No reboot of the device observed during travel. Therefore, based on my experience and previous tests, I confirm that by unplugging the SIM module, I did not have any reboots of the G12. I hope I’ve been helpful.
  • @Antonio Catalano Hey, just checking in many months later to confirm you no longer have reboots since sim module removal?
    Thx again.
  • @The Great Donkey yes, i confirm. I added more variables. Contemporary use of video streaming in addition to navigation software and DAB radio
  • 1 / 2
  • 2
