I installed a G13 in my 2015 Toyota Tacoma the other week with the CB004-1 harness.
The built in microphone is very quiet. My wife said I sounded very far away. Is this normal? In the factory settings the mic level was set to 0, should I try higher? Can this radio use my OEM microphone that is pinned into the 28 pin connector going into the radio or is it only the built in mic or a mic provided by the 3.5mm jack on the harness?
Second my audio for music using Android Auto sounds incredibly tinny and flat. I've been playing with the equalizer/DSP settings. Disabling the Dobly DSP seems to help a little but it's still very lacking. Is this normal? I've seen some threads saying the firmware may be the culprit.
Lastly the back up camera is very slow to come up. The image and everything looks great but when I put it into reverse I'm waiting about 5 seconds with a black screen before the image comes up. Is this normal behavior?
Here's my head unit info
