Valet Lock
  • I just realized you can bypass the lock and access apps as usual
  • @ZAKI KADOURA Hi ZAKI,
    Did you set a password on Valet Lock??
  • I did set a password...so if I have apps running while locked and I swap down on the screen and tab on the window icon, I see the list of open apps. At this time I can select anyone of the and access. The system without unlocking.
  • @ZAKI KADOURA Hi Zaki,we just check on the latest version,there is no problem.please try to update the system to the latest version:
    Please update the Firmware to the latest version via the link below,here are some tips to help you get it done:
    ①Vivid13 Version(20250217):Make Sure your unit is QCM6125 Andorid 13
    1.Download the documents  through the link on your computer/laptop.
    2.Format the USB drive(FAT32 Format) before copying the Update.zip file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
  • Would this version work with my DSP system? It was updated with a version provided by Dasaita support last summer to vivid 13 from vivid 12.
  • @ZAKI KADOURA Your version already the Vivid13, so you may try it.
  • So I did try it.... As I expected, the update is for DTS systems....mine is DSP It didn't work. I will reinstall the older version that was sent to me last year.
  • @ZAKI KADOURA Actually the Android 12 can't update to the Android 13
  • So last year Dasaita support helped me fix an issue I had at that time.... They provided me with this special version of vivid 13 to replace my G12 software... So I did get an update from android 12 to android 13 and that special vivid 13 copy is so far working great except with that glitch with valet Lock... I can survive with it... Not that big of a deal to fix it.
    Thnaks
  • @ZAKI KADOURA
    For your information, Vivid 13 is DTS system . Your unit is DSP system.
    You updated the Vivid 13 DTS, so your DSP system can't work on your unit.
  • True, that is why I reverted back to the initial vivid 13 I was provided with last August since it support DSP.
  • @ZAKI KADOURA
    Thank you for your reply.
    You could try to update to back your original vivid 13, it is the latest version.
    We've stopping update the vivid 13 DSP version.
