@David Karlík
Sorry for the late reply. Please press and hold the RST panel button by pin for 15 seconds to enter the factory setting interface to do the factory reset.
1.Remove the car’s Radio fuse and wait for 3 minutes.
2.Reinsert the fuse and simultaneously start the car’s ACC while you are pressing the reset button of the unit until recovery menu appear.
RST Video Tutorial:
Hi, hard for me to believe it but this actually worked and radio started. Thanks so much. Any idea why this happened and how to prevent it in future?
I'm experiencing the same issue with my G13. Do you have any idea what might have caused it and how to prevent it from happening again in the future?
@David Karlík @Nate L
May we also have a picture of Settings>About machine>Build number?
@Nate L
Thank you for your reply.
May we know is the suddenly dead still happening after you update the firmware to 20250331?
Yes, the random shutdown issue is still happening even after updating to firmware version 20250331.
I also noticed that the fan app shows the unit running at around 60°C to 65°C, even though this G13 unit does not have a fan installed. I'm not sure if the temperature reading is accurate or if it's contributing to the shutdowns, but I wanted to mention it in case it's relevant.
Please let me know what the next steps might be to resolve this.
Thank you!
@Nate L
Thank you for your details.
When the fan app shows the unit running at around 60°C to 65°C, could you go Settings>Car>Factory Settings>Password: hcttest31 to check the temperature ?
May we also have your order ID ?
@Nate L
May we know the details of FAN APP? Can it be downloaded on Google play store?
Our technical support would like to test and check this app.
The FAN app came pre-installed on the Dasaita G13 and is not available on the Google Play Store. It's part of the system software.
@Nate L
May we have a picture of FAN app?
@Support Dasaita hi sorry for late response, find photo below
