Toyota 4Runner SR5 2012 Backup camera not work
  • back of Toyota headunitMy order SP-DA7151 April 7th 2025. I can not get the backup camera to work on my 2012 Toyota 4Runner SR5.
    I do not have the bose system. I have tried the settings in the menu. I have tried the different yellow camera rca plugs. If I put the car in reverse nothing happens on the display.Stock headunit
  • @Mark Tammi
    Thanks for your message.
    1、
    Please make sure that you are using power cable CB004 and it has been connected the CanBus box well.
    About the backup camera connection, it needs to connect Yellow RCA "Cam In" with Yellow RCA "Camera".
    Please firstly find out the suitable white plug(#4 or #4-1) to connect with car original plug,
    then connect yellow RCA "Camera" of that white plug with yellow RCA "Cam In".
    2、
    Please confirm the settings:
    1).
    Settings > Car > Factory settings (password :126) > CanBus > Canbus > 8.
    2).
    Settings > Car > factory setting (password :126) > Other > Reverse Detection > Enable.
    3).
    Settings > Car > Factory settings (password :126) > Other > Front Camera > Off.
    4).
    Settings > Car > Factory settings (password :126) > Other > Switch to front camera after reverse > Disable.
    Finally, tap "Apply" > "Exit "> "OK", then Reboot.
