Just got this today and went to install it. Everything went smoothly until I tried to use the backup camera.
I'm using the CB004 plug and have tried both camera yellow RCA plugs, same issue on both. Shift into R and the screen is just black with yellow triangle and exclimation in it.
REAR Camera Is OEM
@Zachary G
Thank you for your contact .
May we have your order ID and a picture of your OEM unit ?
Please try to go F-cam APP to check if you could see the view for backup camera.
@Support Dasaita I tried the Fcam and that did nothing. Order was from Amazon ID 111-8983771-9921810.
I tried to upload a picture but it just takes my post away.
@Zachary G
Please also provide the belows information to us.
1. A picture of your OEM unit (back and front view)
2.Some pictures of your OEM connectors to show the OEM wiring,see this picture for reference
@Support Dasaita I keep trying to upload pictures and it just says post is awaiting approval
@Support Dasaita I resolve the issue myself you have to move the computer box that's that red color and put it on the other harness
@Zachary G
Thanks for your update.
Yes, the plug an play need to be connected with a CANBUS to support the factory functions.
