Installed this radio in a 2015 Toyota Tundra a few weeks ago. It will just randomly shut off to a black screen and the only way to get it to work again is to use the reset button.
@Shawn Bennett
Sorry for any inconvenience caused.
Please check the tutorial below then try to update the firmware.
System Firmware-Vivid13-20250401:
https://www.dropbox.com/scl/fi/fira9nrfce11uuh1l677h/update.zip?rlkey=joslwy52x2ncc6hu6ni9ax7np&dl=0
I updated the firmware as instructed with no problems. After a few days the radio shut off agin and I had to reset again. What next? I'm happy with the radio if we can get it to not reset like this but otherwise i will return it.
Here is my current version.
@Shawn Bennett
For further confirmation, please tell us when in black screen,
1). whether it can continue to play the audio(music/radio etc.),
2). whether the panel touch buttons can light,
3). whether it can give you response once you tap the touch screen or press the touch buttons.
When the radio gets a black screen there is no audio, no buttons will light up or respond to touch and no screen response. Restarting the vehicle doesn't change anything. The only resolution is to reset the radio.
@Shawn Bennett
Could you please tell us how long after startup will the black screen happen usually?
Besides, please confirm how long does the reset process takes.
Thanks in advance.
Having the same isssues and the reset button does not work for me. The only fix was having the fuse taken off and reconnected to get the radio to turn on. i feel like a physical on/off buttong would have been beneficial for situations like this.
@EROD
@Support Dasaita The timing of when it shuts down varies a lot. It may go days without a shutdown. Once I hold the reset button down for 15 seconds the bottom buttons flash and unit reboots which usually takes about 30 seconds.
@Shawn Bennett
If possible, could you please assist to print the log data?
Please kindly try to follow the instruction below:
Step1.
Remove all external devices, such as USB drive.
Step2.
After booting, go Settings > Factory settings(password: hctlog&).
Step3.
Once it shuts down during driving, hold the reset button down for 15 seconds to reboot unit.
Step4.
After rebooting, go "FileBrowser" App to find out the ".log" file(alog, klog).
Step5.
Connect a USB drive, and copy the file to it, then send the file to us.
We appreciate for your time in this matter.
After changing the setting you referred to above, the radio has rebooted twice. Once on May 27th and again on May 29th. Please advise how you would like me to send the two log files as I cannot upload them here.
@Shawn Bennett
Please send the log files to our mail and indicate your order number as well.
Thanks in advance.
✉️Email: support@dasaita.com
I emailed the files to the email address provided.
@Shawn Bennett Okk,thank you for your time in this matter.Let's talk in the email.
Can you give an update where this issue stands? Any feedback from the engineer after I sent the logs? There is clearly something wrong either hardware or software. Please advise next steps.
