JBL Center and rear speakers
  • Hallo suppert
    I have the G13 unit ( sept 2024) on my 2017 Rav 4 wiht JBL speakers  and I am so far very pleased white it.
    Only much later do i notice  that the rear and centre  JBL speakers are not working .
    Can you  help me to fix this ?
    Thxs  Pieter versluis
  • @Pieter Versluis
    Hello, Pieter.
    Please firstly check if you have connected the speaker cables well.
    Then please try to go "Amplifier App > Delay > Auto > All" to move the crosshair to the center,
    then see if all speakers have sound normally.
    In order to help you better, please provide your Order Number to us.
  • Hello
    My order number SP-DA5731. Delevired  24 sep 2024
    I Will check  for the second time rear speakers kabel
    Thxs pieterversluis
  • @Pieter Versluis
    Please try to check it at your convenience.
  • Hello
    I have check the kabels
  • The only kabels are not connected are see the bleu circles
  • @Pieter Versluis
    For your information, the blue circles are used for the aftermarket amplifier.
    Please ignore it if your amplifier is not aftermarket.
    Please refer to attached picture and make sure that the White Plugs of speaker cables have been connected properly.
    To further confirm, please tell us how it goes after going "Amplifier App > Delay > Auto > All" to move the crosshair to the center.
    1. Hello i check the kabels  zie picture
  • And i check the audio setting you ask
  • Still no speaker in the rear
  • @Pieter Versluis
    System Firmware-G13-202504523:
    https://www.dropbox.com/scl/fi/a5h978wsreg9uuipf6bw1/update.zip?rlkey=p77ztea3f3gdhu24t0845i2mq&e=1&dl=0
    MCU-4.16b:
    https://www.dropbox.com/scl/fi/0ihjcsi6snloq2s1kmskv/hmcu.img?rlkey=gqylhwmievf23h5ksqa7xvtyy&e=1&dl=0
  • I noticed I have this morning that I have the same problem. No sound to rear speakers. Checked cables, made sure the rear speakers weren't muted. When I mute the two front speakers everything is silent so they're the only two that work.
    could I update with the same firmware and MCU? 2021 RAV4 with JBL speakers. G13 installed. Build and MCU below:
  • @Jeff Savage
    zst27_sc138_13_(20250311)
    ②4.15f:
    https://www.dropbox.com/scl/fi/zjk57mppsli9nnmc9vubs/hmcu.img?rlkey=buxs8jrlxzn00j4488ze6sc0d&dl=0
  • @Support Dasaita Is the zst27_sc138_13_(20250311) version a newer, or older version than the zst27_360d version already installed? The already installed version seems to have a 20250522 date whereas the one you suggest is 20250311.
    Am I downgrading? Will I lose any current functionality?
  • @Jeff Savage To better confirm,could you please provide your order details to us?
  • @Support Dasaita Order SP-DA7334. I've updated to 20250311 and the issue with no sound from the rear speakers persists.
  • I am having the same issue with my 2007 Tundra w/JBL.  No sound rear speakers and no sound from subwoofer.  I also did the firmware update and still no rear speaker and no subwoofer.
  • @Jeff Savage
    And please go to the DTS APP to check if the mute button is disable.
    And please set to "ALL"and"Manual"to see how it work.
  • @jose gonzalez Hi jose,what unit version do you have?
  • 1 / 2
  • 2
