I purchased the unit from Amazon 7 days ago installation was simple 👌 but after few days I noticed that went the weather is hot more than 60° the stereo loses audio and after I turn the AC on after few minutes the sounds comes back, at first I thought I contacted something wrong so I took everything a part and installed again but nope still happens any clues or do I need to return the equipment for a refund at Amazon thank you.
@Jorge Andres Mata Diaz
Besides, please go Settings > Car > Factory Settings > enter password(hcttest31),
and send us two screenshots of the CPU temperature respectively when audio works well and it loses audio.
@Support Dasaita Thank you I have all the information you are requesting, exept for when is lossing Audio, so I will have to wait I do have another question how do a removed the CPU monitoring small screen, so I can removed it thank you
Thanks for sharing the information.
Please try to use a Pin/Paperclip to press and hold the RST Button for 15 seconds to do the factory reset to see if it can remove the CPU monitoring small screen.
https://www.dropbox.com/scl/fi/6mhzgijcv059wo2s9octl/G13-RST.mp4?rlkey=366exgktisqwb4ml1elqoge2u&e=1&dl=0
Sorry for we cannot locate your Order Number, could you please simply copy it to us?
Besides, please tell us if you have connected the RCA cable.
And please confirm whether it will lost all audios(Mucic, Video, Radio, Navigation, etc.)
Sorry here is the order number was purchased with multiple items, on the same order thank you. And no I didn't connect the RCA from that receiver, but I did on the amplifier section since I had previously installed sistem
Don't worry, we have arranged the personnel to follow up on your order.
Please pay attention to your mail box and continue to communicate via email.
✉️Email: team@dasaita.com
