Went to reset the device due to phone connectivity issues, now ZLink gets stuck on loading for over 30+ minutes while connected to wifi/hotspot. Ive had it for a couple years so it might be cause of an update issue
@Justin Sanqui
May we have a picture of your UI to send the related firmware?
@Justin Sanqui
Thank you for your reply.
Based on the information you provided, it is andriod 11 unit.
Here is the lastest version for Max 11 .
Max11(20231216)
https://www.dropbox.com/scl/fi/w0wrjc80ksuxy3fe08gjw/update.zip?rlkey=tyoc18w33q1py8o1ooo2gw7yr&dl=0
Thank you for your time.
I now have the activation QR code, I attached it to the original post, is there anything else I need to do?
much appreciated!
@Justin Sanqui
We've forwarded to the technical support,please try to connect the headunit to the internet within 48 hours.
Thank you for your time,keep in touch.
