JBL Subwoofer
  • Hello @Support Dasaita and forum members, I have recently installed an Android G13 head unit with the correct harness per the instructions.  However, my JBL Subwoofer in my 2019 4Runner is not producing any sound.  All of my other speakers are working just fine, it is just the JBL Subwoofer.  Please let me know how to enable the JBL Subwoofer in one of the Settings menus or in the Developer Menu.  Thank you!
  • @Joseph Rohan We are wondering if you have already go to the EQ settings > volume to crank up the Sub volume.
  • @Support Dasaita Yes, I did try cranking up the volume on the subwoofer alone...it was already maxed out when I got to the menu.  I muted every other speaker (front, read, and center) and could here nothing coming from the subwoofer. (See picture for reference)
    I think I may have a new problem now though.  When I attempted to change the settings on a different sub-menu in the 'amp' menu, no I have no sound coming from the rear speakers.  Please help me reset this.  I tried to hit the 'reset' button but that did not work.
    If this second problem is fixed, I still do not have any sound coming from the subwoofer.  Would an update to the software fix this?
  • @Joseph Rohan We would like to tell you that we have a subwoofer booster, we are wondering if you consider purchase one. You could send us message to the product support team to better confirm:
    💌: support@dasaita.com
  • @Support Dasaita I would consider that but I was told the G13 would play my JBL subwoofer. Why can't I play it without the booster? Also, support@dasaita.com is going to be sending me an update file. Shouldn't that work?
    Also, what about the no sound coming from my rear speakers now?
  • @Joseph Rohan Hi there, the head unit supports subwoofer output. For your car model, we suspect the the subwoofer output is not big enough that you could hardly hear it, it's why we suggest you to purchase a booster instead of replacing the subwoofer.
    Thank you for your understanding, please add your order number in the email if possible.
  • For now, I would be satisfied with hearing my rear speakers with my front speakers.
    How do I fix this besides a factory reset?
  • @Support Dasaita I tried a factory reset and that still did not fix the issue.  Do you think it is an issue with the Canbus?  Is it possible to get a firmware update file and/or a Canbus fix for this?
  • @Support Dasaita Update: Mia from Dasaita Support sent me an system/firmware update file and it worked!  My rear speakers are now producing sound now and so is my JBL Subwoofer!  Thank you, Dasaita Support!
  • Hello @Support Dasaita Hello Would you please send me the system/firmare update file too (my model is G13/ vivid13), I also have the same problem with my radio. I'm using CB004 arneses and have hthe JBL Subwoofer without working in my 4unner limited 2019.
  • @Harry Rojas Sanchez We have sent you message of some adjustment and we need About Machine info before guiding you the update.
  • Hello@Support Dasaita, I too seem to be having the same issue as@Harry Rojas Sanchez. Would you please send me the system/firmare update file too (my model is G13/ vivid13), I also have the same problem with my radio. I'm using CB0047 harnesses and my JBL Subwoofer, Center and Rear speakers do not play any sounds. I have 2016 Toyota Tacoma with the factory JBL system.
    Additionally the back up camera is not working.
    Please help. Thank you!
  • @Joseph Rohan I am having the same issue you had. My rear camera is also not working. Do you think you could email me this firmware update? 😁 Stephenperkins18@yahoo.com
  • @Stephen Perkins
    No problem, we have contacted your email.
  • @Support Dasaita please send me the firmware update also. I'm having the same issue
  • @mjolnir8844
    Please go to Settings > About machine and send us a screenshot about the current Build Number and MCU version.
  • @Support Dasaita can you please email me the update also. I have V1.
  • @Josh Br No problem,please go to Settings > About machine and send us a screenshot about the current Build Number and MCU version.
  • @Support Dasaita I am also having this issue can you send me a link to update my firmware.
    I am having the same issue with my Toyota Rav4. I am getting no sound from my rear speakers or subwoofer. I have tried all the different suggestions in the forum including changing the delay amplifier settings and volume settings. My info is below:
    Model: QCM612
    Android Version: 13
    Build Number: QCM6125 13 S10A_123.eng.hct20260409.193809 NA-V1
    MCU version: MTCH_HA4Z_V4.12b_1     Apr 19 2024 10:04:11
  • 1 / 2
  • 2
