After using the steering wheel controls several (dozens of) times to manage music playback, calls, etc., the device restarts. After restarting, the connection with Android Auto only works via cable (this might be more of a phone issue, as it unexpectedly lost communication). Originally, the device would completely freeze and required a hard reset by inserting a pin into the reset hole, so the situation has improved with the version I currently have installed, but it still fails periodically. Is there a newer firmware/MCU version I could try to see if this problem gets resolved?
