Dashboard clock 2023 Camry
  • I have a G13 and cannot find a setting to change the clock on the instrument cluster. I had a JBL head unit and that setting was in the menu on the head unit. How can I set the clock on the dashboard now?  I have updated the MCU and FW.
  • @Paul A
    Regarding the clock issue on your dashboard, here is the explanation:
    The clock on your original car dashboard was controlled directly by the factory head unit.Since you have replaced it with our Dasaita head unit, the original car functions rely on the CANBUS for support.
    At present, the CANBUS does not support controlling or synchronizing the dashboard clock.This is a compatibility limitation, not a defect of the head unit.
    You can check the accurate time on our head unit screen, which is auto-synced.We will keep improving the protocol and update you if this function becomes supported later.
    Thanks for your time and understanding.
