toyota 4runner limited 2019 with jbl zlink6
  • Hello!
    Car: Toyota 4Runner, 2019 with jbl
    Phone: iPhone 17 Pro Max, iOS 26
    zlink6 v6.0.31
    build number
    QCM6125 13 S10A_123 eng.hct.20250903.190343 EAU-V2.1
    MSU version
    MTCHS_HA4Z_V4.16b_1
    Apr 25 2025 15:22:41
    I started having an issue with CarPlay in ZLink5: it would randomly disconnect and then would not reconnect. Rebooting the head unit and setting everything up again did not solve the problem.
    After installing ZLink6, CarPlay started working stably, but now the head unit itself started rebooting on its own quite often. This never happened before.
    Could you please help me find a solution to this problem? Have you latest software/mcu update for my build?
    Thank you!
  • @Mariia Mishchenko
    Regarding CarPlay issue, here are some feasible trouble-shootings for you.
    Check whether WiFi antenna has been screwed well.
    Confirm if the Bluetooth name(CAR-KIT) and PIN number(0000) are displayed on the unit:
    Settings > Connected devices > Bluetooth > Device Name; PIN Number.
    Clear records:
    Settings > System > Reset Options > Reset WiFi, Mobile&Bluetooth.
    Use other phones to test how it goes if possible.
    If no luck, Please check the update tutorial below then give it a shot.
    System Firmware-G13-V2-20260410:
    https://www.dropbox.com/scl/fi/jwoqmanj15r8ktlroloy6/update.zip?rlkey=my6wh60a4z2r555fw6zd6zx57&st=kdihaggb&dl=0
    MCU-4.17f:
    https://www.dropbox.com/scl/fi/9t1gp2mkk3ertqyybpf5j/hmcu.img?rlkey=rs1abdmvfbk53331a024bps8j&st=dzwvztlg&dl=0
