@Aramis Gonzalez
Thank you for your reply.
Here is the latest Universal version /UI for the PX6 Andriod 10 .
If you don't mind the OS ,you could try this version.
@Aramis Gonzalez
@Support Dasaita Hi, I tried the new OS that you provided and it still didn't work. I have a iphone 17 PRO with the new IOS 26. I think it not compitable. By any chance do you have another firmware?
@Aramis Gonzalez
Still can't connect to CarPlay? Can Bluetooth connect normally?
@Support Dasaita It connects to CarPlay, but it consistently disconnects. Bluetooth functionality is not the issue, as it successfully connects to CarPlay. The previous firmware would at least maintain the Bluetooth connection when CarPlay was disabled. With the firmware you provided, neither the CarPlay nor the Bluetooth connection is stable.
@Aramis Gonzalez
In this issue, please try back to the vivid version.
It is the latest version. As the new system is introduced, we will gradually stop supporting older devices to ensure that the new system can run better on new devices while protecting the data security and device performance of users of older devices.
Vivid10(20250401)
Thank you for your time and understanding.
So, are you saying that my current device, the PX6 Max 10, does not support the new iPhone 17 Pro with iOS 26? If that is the case, do your new devices support the new iPhone 17 Pro with iOS 26? Do you offer a discount on purchasing a new Dasaita Android radio if we trade in the old one?"
Is there a way to use wired Apple CarPlay to see if that works better? Mine does not connect through the wire; it only connects through wireless Apple CarPlay.
@Aramis Gonzalez
For your information, the USB cable for the iPhone 17 Pro is USB-C . This cable doesn't fit the Dasaita USB cable , so your MFI cable doesn't fit to support the wired carplay.
