@Aramis Gonzalez
Thank you for your reply.
Here is the latest Universal version /UI for the PX6 Andriod 10 .
If you don't mind the OS ,you could try this version.
@Aramis Gonzalez
@Support Dasaita Hi, I tried the new OS that you provided and it still didn't work. I have a iphone 17 PRO with the new IOS 26. I think it not compitable. By any chance do you have another firmware?
@Aramis Gonzalez
Still can't connect to CarPlay? Can Bluetooth connect normally?
@Support Dasaita It connects to CarPlay, but it consistently disconnects. Bluetooth functionality is not the issue, as it successfully connects to CarPlay. The previous firmware would at least maintain the Bluetooth connection when CarPlay was disabled. With the firmware you provided, neither the CarPlay nor the Bluetooth connection is stable.
@Aramis Gonzalez
In this issue, please try back to the vivid version.
It is the latest version. As the new system is introduced, we will gradually stop supporting older devices to ensure that the new system can run better on new devices while protecting the data security and device performance of users of older devices.
Vivid10(20250401)
Thank you for your time and understanding.
So, are you saying that my current device, the PX6 Max 10, does not support the new iPhone 17 Pro with iOS 26? If that is the case, do your new devices support the new iPhone 17 Pro with iOS 26? Do you offer a discount on purchasing a new Dasaita Android radio if we trade in the old one?"
Is there a way to use wired Apple CarPlay to see if that works better? Mine does not connect through the wire; it only connects through wireless Apple CarPlay.
@Aramis Gonzalez
For your information, the USB cable for the iPhone 17 Pro is USB-C . This cable doesn't fit the Dasaita USB cable , so your MFI cable doesn't fit to support the wired carplay.
hello i have updated the android 9 with the firmware of android 9 in your forum
but it didn´t update to a new android 10 or 12, it has remained in android 9
i can´t update it to newer versions?
HCT Firmware PX6 Android 10 Make Sure your unit is PX6 Andorid 10
@Support Dasaita you do know they have regular USB to usb C right? So I'm asking you how can I get it to work with the wire CarPlay feature? Do I have to download a APK?
@Aramis Gonzalez
It is a shame that we don't have suitable USB adapter to fit your iPhone 17 PRO USB cable.
For any other helps,please get in touch.
@Miguel R
Android 9 can't be updated to the Android 10 ,Android 11 or Android 12
howdy,
I have a 2015 Toyota Corolla with a Android 12 and qcm6125. I have had the radio for awhile now and I have liked it. Is there a way that I can reset it to factory settings since I'm having the following issue? when I connect anything with CarPlay or android auto I do not get notifications from the apple maps, Waze, Google Maps. It has QCM6125_20231017-1733 installed and wanted to update it. I also wanted to get the SIM working but I also do not have that updated firmware. Is this compatible with an eSIM? The help would be appreciated!
@Jacob
Dear customer,
Thank you for contacting Dasaita.
Considering any improper/unnecessary update could be risky, please go to Settings>About machine and provide the following version information:
Thank you for your time and cooperation in advance, we look forward to your reply.
Kind regards,
Dasaita
I cannot get the picture to upload. Here is the info.
Android version
12
Kernel version
4.14.190
#174 Tue Oct 17 17:40:18 CST 2023
Build number
QCM6125 12 S10A_123 eng.hct3.20231017.173055 NA
MCU version
MTCH_HA4Z_V4.06_1
Sep 11 2023 20:01:17
