Is there a setting to set the lowest volume or maybe increments ? My unit on the lowest volume is way to loud have to take it to zero to have conversations.
@Tom Hutchins
On Factory Settings (Pass: 126) you can adjust the Main Volume for differnet outputs (Bluetooth, Radio, System) that the MCU mixes . Check it you solve your issue by lowering the SYSTEM volume
Thanks Iker ! That fixed the issue!!
Where is this setting on the Vivid? I looked but I was unable to find this.
Did this work for you? What did you set it too? I'm having the same issue
