3) press the reset button (pin hole) with a needle in order to check if the image comes again to live....if not:
4) try to upgrade (again) to latest mcu for your unit (mtce or MTCH) but this time from the recovery menu by means of pressing the reset button (pin hole) for about 25-30 secs...
First you will notice blinking lights ...but continue pressing reset until you see the unit is showing the logo
The MCU you used is "compatible" but something in the factory settings has been changed due to the fact that you never upgraded the MCU with your exported settings.....
Without image you can't access to factory settings so the only way is by means of accessing the recovery menu (the procedure I described earlier is for andeoid 10, on previous versions the procedure was slightly different)
First of all switch off your unit (remove fuse for about 2 min ) or remove wires to ensure you are booting the unit from cold and not waking up from sleep.
yes yes, even though it's black you touch and you hear beeps from the app and you also see a clear black, the strange thing is that by resetting Recovery doesn't start, but well I can't do anything.
Hi @Dasaita Official , I have experienced for the last 2-3 months the same exact problems shared by @Juan Perez . The unit is 2.5 years old and it was purchased on Amazon (Order# 112-0171974-5943430). Any help is appreciated. Thank you!
@Dasaita Official I'm having the exact same problem. I've tried every recommend fix but nothing has worked. I will add that my steering wheel buttons also work along with everything else described here.
