Now when I reset the factory some red letters have come out, let's see if you know how to remove them.
Thank you.
Thank you.
You have to install the dasaita MCU upgrade to remove those letters.
Would you mind to explain us how did you get you unit alive?
I did exactly what you told me, although it took me more than a week to get it.
I put the 2 files, the DMCU.IMG and the DMCU.EXT, in the pen and based on trying until it grabbed and the Recovery came out.
I had the MCU 3.78.1 I have updated it again but those letters have not gone away. I would still have to insert a previous version. You tell me.
Tendría que insertar una versión anterior.
Dígame usted.
I can give you a way of removing that annoying message....the message is due to the MCU you installed previously did not matched with the manufacturer....but now that you have reinstalled a dasaita MCU file...the.message should be removed.
I read that you must to force the update more times until the message be removed....would you mind to update again (up to two times) the MCU with the same HA_3.78 and check if the message disappeared?
If after this the message still there then install the following app into your headunit, run it and reboot
