Vivid 11 and Dasaita ODB-II Scanner
  • I have my Vivid 11 installed in my vehicle.  I have the Dasaita ODB2 scanner I purchased for it and have it plugged into my ODB2 port.  I have purchased the Torque Pro app to get readings off it, but Torque does not find the device to pair with it via Bluetooth.  What do I need to do to troubleshoot this and get it working.  I know Bluetooth and Wi-Fi are working as I can use ZLINK for CarPlay to my IPhone.
  • @Brandon Shiers First you have to pair the ODB device to the Unit, before using Torque. Check the ODB user manual for the Pairing Code needed (probably 000 or 1234). This code must be setup on your unit prior to the pairing in order the pairing could occur.
    then once paired...you can use the Torque app
  • @Iker Gomez yes sir that was it.  I had to change it to 1234 and I'm up and running!  I think I'm having a couple of other issues so I'm going to be opening another thread for those.  Thank you for the reply!
