Adding FM antenna for 7inch generic HU
  • hello.
    does anyone know if we are able to add additiona external FM antenna to properly receive FM signal? what are the connection types and if any recommendation for the FM antenna?
  • @chee meng chue you will need an adaptor for your brand and car model to a standard FM antenna. By this way you will be using your stock antenna amplified on the dasaita
