Does anyone know how/if you can watch the backup camera without physically going into reverse?
This is useful if towing or simply want to see what is behind your car.
@Nathan Darby did you get a response?
I Can.
If you have the F-Cam APP, when it opens you can select the camera icon on the left and it switches to the reversing camera. I use it while towing to keep an eye on everything.
@Andrew Sloane @Dustin Fields @Nathan Darby Please let us know if your cable is with a canbus or without canbus. If you cable is without canbus, you must connect the reverse cable while you can wiring the backup camera. Here is a wiring instruction for your reference.
@Andrew Sloane Where can you get the F-cam app. I tried the play store.
@Michael Mitchell
Please try to do as follows:
Settings > Car > Factory settings (password :126) > Other > Front Camera > On > Apply > Exit > Reboot.
