PX6 Touchscreen stopped working.
  • Hello@Support Dasaita, since the updates to Scout OS 3.5.6 my storage is at 100% use and will normally pop up Bluetooth or Scout has crashed, making the unit unusable. I can get into setting but I do not have anything else installed. I have a small cache in Google that I clear as it will rebuild even though I do not use it. When I clear that cache the system will start and run until it is shut off again. There are no photos, videos, files, or other apps installed. This is just the system folder, and Scout being 52GB. How can I correct this, or can Scout be side loaded to run on a usb so it is not stored on the main memory? Or is there anyway to upgrade the memory. Thanks
  • @finachem We are wondering if you consider download the vivid firmware which has Scout Map pre-installed?
  • 1
  • 2 / 2
