Night Mode/Brightness
  • After installing the Android 12 head unit in my RAV4 2018 I have noticed the brightness is still too high for night driving even after changing the brightness to the lowest setting in both the regular settings and the factory settings other menu. The night mode slider does nothing to change the screen brightness or any other noticeable difference. Please advise or update. It's hard to drive at night with the light from the screen so bright my headlights look dim outside.
  • @Hayden Guild It will change but the brightness may be associated with the wallpaper. You could see the change in our following video.
    https://www.dropbox.com/scl/fi/4jd0nd1nhn5aej57ii6tv/G12.mp4?rlkey=38puc3rq1fvpificjwsp0w5dt&dl=0
  • @Support Dasaita  this is the opposite of the issue. The screen is too bright while driving, no matter the app or background. I found a work around to get into the accessibility settings to dim the screen further but it's very frustrating to go through 4 menus every time I need to drive at night or early morning.
  • @Hayden Guild We have reflected your feedback to our engineer, they are studying on new firmware to improve your situation. Your understanding will be appreciated and  once there is new version, we will release on this forum.
  • I'm having the same issue on my g12. The side buttons light up with the headlights, but the screen brightness does not change, and it's too bright.
  • @Gavin Swanson Hi Gavin,
    Thank you for your feedback.
    Even if in night mode the screen still so bright for you?
  • I have the same issue with my 4 runner. I understand this may not be problematic for people in an urban environment but I live in a rural one and am often the only car on the road at night. There are no street lights so it is really dark. The screen of this device is so bright no matter what that I want to deinstall it. Please make a screen off button that allows music to still play if you cannot make the screen further dimmable. This is unacceptable that this simple feature does not work.
  • @jb
    Have you set the night mode?
    1.Go to Car > Factory Settings > Enter 126 > Other > Panel LED control > By head light. Then apply and exit.
    1)When headlights are on, it will automatically switch to nighttime mode.
    2)When headlights are off, it will automatically switch to daytime mode.
    If it is not luck,please try to go Settings>about machine>Build number&MCU.
    Kind regards,
    Dasaita
  • Good morning, I’m joining the request. The brightness is very high and does not adjust automatically. The adjustment range is also very limited compared to smartphones, it’s like dimming from 100% to 90%, and it can't go lower.
    When will this issue be fixed? My current radio version is G13 QCM6125_20240903-1414, and I noticed that a newer update is available. Has this been resolved there?
  • @Ariii
    Yes,we've updated the new firmware.
    We‘ve sent to your email,please check it on your email
  • @Ariii
    I have the same problem, I have the latest software but nothing has changed, it's still much too bright at night. But I installed the Night Screen app on the Playstore about six months ago and it works very well.
  • @AO1967 worked perfectly, thank you.
  • Hello I have a HA2248GH2-G13a-CP-2K-4 and I have the same issue,  with all the brightness settings set to the lowest setting, its still to bright when i drive at night/early morning. Is there a firmware update that I can install to get this issue fixed.
  • @Red Tacoma
  • I added the image, and I have a message its waiting for approval.
  • @Support Dasaita  can you check the image approvals for my image.
  • @Red Tacoma
    Sorry we couldn't locate the image,please double check
  • Here is the text extracted from the image
    Model
    QCM6125
    Android version
    13
    Kernel version
    4.14.190
    #179Tue Mar11 10:49:15CST 2025
    Build number
    QCM6125 13S10A_123 eng.hct.20250311.103730 NA
    MCU version
    MTCHSHA4Z_V4.16b_1
    Apr 25 2025 15:22:41
  • @Red Tacoma
    Dear customer,
    ②4.16g MCU:
    https://www.dropbox.com/scl/fi/61d69lkomwkf005tvgigb/hmcu.img?rlkey=emrb91895qodihn8f9ih27e7x&dl=0
    2.Format the USB drive(FAT32 Format)before copying the Update.zip hmcu.img file to it, then insert it to the USB cable,and it will pop out the firmware updating tips on the screen.
  • @Support Dasaita  I've installed the new firmware and MCU, the brightness is still to high, I can mitigate this by using the Night screen App from google play store.
