@R. L. Sorry for the late reply due our Tomb Sweeping Festival in China. We would like to tell you that the ribbon controls the touch key. You need to reconnect the ribbon after remove the small internal microphone.
@Support Dasaita Hello,
Yes, I see I no longer have control of the volume knob as well, the lights no longer light up. So will reconnect ribbon cable.
Where is the small internal microphone located? On the circuit board that controls the volume and lights?
@R. L. We would like to tell you that the internal microphone is as below, it's risky if you remove it in inproper way. Could you kindly wait a few days for our new firmware, we are testing now.
@Support Dasaita Hello, thank you for the updated information, appreciate it. Yes, I will wait for the firmware update. Will await for your reply when availalbe.
RL
@R. L. Really appreciate your understanding and cooperation.
@R. L.@Support Dasaita I am waiting on the firmware update as well...or any way to be able to disconnect the internal mic on the Dasaita 12, that doesn't require cutting any wires on the unit. Thanks in advance!
@Victoria C Hi, Yes, for now I disconnected the ribbon cable to the circuit board for the left side. Not only does that disconnect the mic, it also disconnects volume control, mute control and background lights. Not a huge deal at this point as calls are now clear using the external mic only. Also to be noted, I replaced the supplied external mic with this mic: https://shop.enfigcarstereo.com/toyota-4runner-2010-2023-radio-installation-products/
Hope this helps
RL
@R. L. We are wondering if you could spare time to help us in testing the firmware that our engineer release to improve the microphone.
G12(20240411):
https://www.dropbox.com/scl/fi/qdqyklxi3hqkcnx4s56e5/update.zip?rlkey=xlmq6nysk9x3kkk9dwy7e1238&dl=0
We will appreciate your cooperation.
@Support Dasaita Hello Support, Yes I can test. What is the process for installing the supplied firmware? Also, what are the expectations of this firmware? What should I be able to do once this firmware is installed?
RL
@R. L. Please ignore that firmware, we found a small bug that need to be fixed during the test. Sorry for the inconvenience.
@Support Dasaita Sure, will wait for latest.
Is this new firmware meant to fix the internal/external setting in factory settings?
@John Robinson It will improve the sound quality of microphone.
