Rear Camera Wiring Tips of CB047
  • We've received feedback from some customers who are experiencing an issue with the rearview not displaying when reversing, but display rearview on the F-cam App.
    If you're using the CB047, it's possible that you forgot to connect the reverse trigger wires C with C1 or C2. Please check the backside of your unit to ensure the correct wire connections.
    If you need further assistance, please don't hesitate to contact us.
  • hello I have a 2013 non jbl 4Runner and just installed the G13. Everything is working except for the backup camera. The unit does not redo fixed when I am in reverse. The screen does not change when in reverse. How do I fix this? I have enabled backup detection. Do I need another additional harness than what was in the box? I am using the CB005-1+DYX004.
  • @Mark Mark
    Thanks for your message.
    Please confirm the setting firstly:
    Settings > Car > factory setting (password :126) > Other > Reverse Detection > Enable.
    Settings > Car > Factory settings (password :126) > Other > Front Camera > Off.
    3..
    Settings > Car > Factory settings (password :126) > Other > Switch to front camera after reverse > Disable.
    Finally, tap "Apply" > "Exit "> "OK", then Reboot.
    The front&back side clear photo of OEM radio.
  • @Support Dasaita I am also having this issue, I tried the settings above as well as switching from C1 to C2 amI missing something? 2022 Toyota Corolla
  • @Ricardo Sanchez We are wondering if you have connected the Canbus box. Note to connect the Canbus box, select Option No.8, and make sure that reverse detection cable has been connected. Last but not the least, go to Settings > Car > Factory Settings(126) > Other > Enable reverse detection.
  • Hi. I'm having the same issue with the backup camera not showing the image. I've checked all the settings to make sure everything was enabled correctly and checked to the C1 & C2 cables (mine doesn't have them. I'm guessing because it's a new model. Also my Canbus Box is all connected
  • @TylerS405 Please let us know your order number, car year and model and trim level that we could better help. Thank you for your cooperation.
  • Order SP-DA9085 2014 Toyota Camry SE
  • @TylerS405 Please kindly refer to this post:
    https://www.dasaita.com/community/forum/topic/121808/trouble-shottings-of-rear-view-camera-not-working-for-toyota-car-model-with-cable-cb004
