back up camera not detected 17 accord
  • I just installed the stereo in my car last weekend it was a newer version of the one we had that bricked during an update. Everything seems to work but it does not detect reverse. If i open the front cam app I can switch to the back camera and that works. I did go into settings and make sure reverse detection was enabled.
  • @Eminit
    Hi,
    To accurately confirm the compatible model for your car,please provide a clear photo of the OEM Radio to us.
    To ensure the specific solution for your car stereo,please provide us with your Order details(Including Order Number&Unit model&Version)
  • I dont have the original stereo I took that out a few years ago i had a older version of this one i just boght again the serial number on the old one was 78edb2ad27ae5b2d and was the px6 model.
    the new one i just got is
    Order SP-DA7023
  • Make sure the Camera cable is connected to the CAM IN cable,the front camera cable is no need to connected.
  • It is connected to the camera in. as I said the camera works fine but when put in reverce the backup camera does not come on. I can go to the front cam application and manually tell it to switch to the back cam and it will work. I did go into settings and make sure reverse detection is enabled as well.
  • @Eminit
    For the factory reverse camera ,please notice to connect the Cam Vin cable for Audio Output cable.
    If you connect the F-cam RCA cable for AUX input, the camera will show on the F-cam app.
    Please double check your connection, thank you
  • I think there may be some confusion here. The camera works fine. My issue is when I put into reverse the unit is not detecting the vehicle is in reverse. Nither screen will show the back up camera. I know I got the camera in right on the unit because I can go into F-cam app and select the back up camera and I can see it working just fine. So the unit knows that is the back cam. I went into settings and made sure back up cam detection was enabled. However from my understanding is that would only switch the unit to display the back up camera when detected. I dont have that showing or the factory screen up top when I put in reverse which I belive runs through the can bus. but the screen is working through the tft driver because it does show similar to the factory display.
  • @Eminit
    Thank you for your details.
    For your order #SP-DA7023, we found that you also bought a aftermarket reverse camera.
    Just would like to confrim the current reverse camera in the vehicle is factory or aftermarket?
  • The current camera is factory I have not installed the other camera yet was going to make the a front camera after we figure out this issue
  • @Eminit
    Please confirm whether the backup page can be viewed in the front camera APP only after shifting into reverse gear.
    If yes,please try to swtich the yellow RCA to check how is it going ? To better check if  there is any mistake in the label.
    Coul you please send a video of showing the Dasait screen when you put the car in reverse and your full connection so we could send to technical support?
    Thank you for your time and cooperation.
  • The back up camera can be viewed from the app any time. The vehicle does not have to be in reverse.
    I made a few videos shared from my google drive can be found below. one video shows the settings in the unit. the other shows the connections and the third shows starting the car and going into the app selecting the camera. without placing in reverse then at the end show placing in reverce with nothing happening.
    https://drive.google.com/file/d/1Vid_0XLEKMu2GClCJzjHQOwWi1q4HcV_/view?
    usp=sharinghttps://drive.google.com/file/d/1Y6KmA0YJWWThWxwmjhojF4dBwvD1ahiX/view?usp=sharing
    https://drive.google.com/file/d/1p0ZlgaUXL2yFPIXNdckGZWAN7sghQyTD/view?usp=sharing
  • @Eminit
    Our technical support advise to send you a new CANBUS to make things worked.
    Just would like to confrim is the small screen working well?
  • yes the small screen up top is working well
  • @Eminit
    Ok,let us send you a new Cable with CANBUS have a try .
    Is the same shipping address as this order  SP-DA7023?
  • Ok thank you.
    Yes same shipping address from my order
    Order SP-DA7023
  • @Eminit
    We‘ve  sent a new cable with canbus via USPS.
  • @Eminit i am having the exact same issue. How did you resolve this? I really like the radio but if my rear cam won't work I will have to return it. I can see the camera in the f-cam app when I change it to the reverse camera. When I put the car in reverse the rear camera does not pop up on either screen. Please help.
  • @lu i
    Thank you for your contact.
    What is displayed on the screen when you shift into reverse gear?Black screen  or No reaction ?
    Please double check you have conntected the CAM VIN cable .
    If possible,please provide a picture of your OEM unit and some pictures for your full connections .
    No worries, we're responsible company and try our best to help .
  • There is no reacton when i shift into reverse. I have connected the cam vin cable to the cam in cable.
  • I have a 2014 honda accord.
  • 1 / 2
  • 2
