Dasiata Head unit toyota rav4 2019 rear camera issue
  • I'm currently having issues with the rear camera. It will work once I reboot the unit, but later when I try again, it won't turn on.
  • @patrick russell
    Thank you for your contact.
    Just would like to confirm the rear camera only work when you reboot the unit?
    What screen is showing when the rear camera won't turn on? Black screen or exclamation point?
    We thank you and look forward to your reply
  • No screen pops up.
    If im on the radio app and go into reverse, nothing happens. It stays on the app and continues to play music. Same thing for any other app.
    No black screen pops up or anything
  • @patrick russell
    Thank you for your reply.
    For this issue, please notice to turn off the car and check the trigger wire C  to C1  or  C to C2 connected properly.
  • @Support Dasaita hello, i checked wire is connected. I tried c2 instead and problem still persists
  • @patrick russell
    Thanks for your reply.
    Please try to do as follows:
    Settings > Car > Factory settings (password :126) > CanBus > Canbus > 8.
    Settings > Car > factory setting (password :126) > Other > Reverse Detection > Enable.
    Settings > Car > Factory settings (password :126) > Other > Front Camera > Off.
    Settings > Car > Factory settings (password :126) > Other > Switch to front camera after reverse > Disable.
    Finally, tap "Apply" > "Exit "> "OK", then Reboot.
