No sound after some minutes. Must reboot !
  • Hello, I have a big problem with the G13 version. Dasaita in my Toyota Chr. Regularly the audio cuts out and I have no more sound. The only way to get the sound back is to reboot the system. It's annoying because it's systematic. The cables are correctly connected, the whole system is up to date. Only the sound from the basic radio application emits sound.
  • @Fabien Cerkownik
    Please go Settings > About Machine,
  • Order : SP-DA6781
    Date : 02/13/2025
    Buid number : QCM6125 13 S10A_123 eng.hct.20240903.141210 EAU
    MCU Version : MTCHS_HA4Z_V4.14e_1 Sep 14 2024 10:24:11
  • @Fabien Cerkownik
    We have arranged the personnel to follow up via email.
    Please check you mail box.
    ✉️Email: team@dasaita.com
  • Thank you,
    I did the update, i will tell you soon if it's better.
  • @Fabien Cerkownik OK,keep in touch.
  • back and I was able to retest during a 2 hour journey. Unfortunately, the problem recurred. Suddenly no sound via Spotify, Dab Radio, Youtube music and Google navigation voice. The only time there is sound is with the basic radio application of which I put a capture in PJ. However, when the sound cuts out, I hear some crackling in the driver's speakers. It's strange. I don't think there is a bad connection of the cables, maybe a problem with the Dab USB adapter which connects the Dab antenna and the Radio antenna to the Dasaita? What do you think?
  • @Fabien Cerkownik Dear Fabien,
    zst27_sc138_13_(20250620)
    https://www.dropbox.com/scl/fi/jstacxfz4l9svgsjchmnr/update.zip?rlkey=hacqwnttcyb7wn7uoostpzwtv&dl=0
    ②4.16e:
    https://www.dropbox.com/scl/fi/dxj9tjs9pnzv9actri0g9/hmcu.img?rlkey=g5hk0gsmuhaxqolypqf28occ8&dl=0
  • Thanks for your reply.
    I checked cable connexion and now it seems better for the sound. System is more reactive.
    I installed New system with your last message, it's ok.
    But now, last problem, i have problem with certification play protect, it's not certified. So now i have problem with some Google apps.
    What i need to do to get this certification ?
    M'y google play store is updated.
  • I added id to the device id. I retry tomorrow to see if the system will be certified. I will let you know.
  • For my first problem : sound mute -} it's all works.
    But now, the problem is : System not certified by google play protect. I tried with the device Id to save it on Google service. It's done but always not certified even after clear cache of play store and google service.
    What to do now ?
    Thanks per advance.
  • I think I understand the problem. The firmware you told me to install previously is an engineer version (eng), that's why Google doesn't certify it. For that I would need the user version (user). Which works just as well, because apart from that, everything works.
