As mentioned in this thread I updated the unit using provided firmware.
Android Auto wireless works fine now BUT volume up/down and next/prev steering wheel keys stopped.
Phone up/down, voice activation, music mode/mute work fine.
In the hidden menu I set SWK as "Canbus" (it was already like that, since when I installed the unit 2years ago).
If I use SWK setup page, when I press phone up/down, microphone or mode I see on the screen that the related command be one highlighted and I can change it.
When I press volume or next/prev nothing happens, nothing get highlighted on the screen.
If I press reset all commands on the screen get deleted but again , pressing volume SWK doesn't show up anything on the screen. I will attach pictures below.
Before the update SWK were working fine.
@Mcgyver83
Please go:
Settings > car > factory setting (Password: 126) > CANBUS.
If it is 8, choose "NO" to apply, after the reboot, re-choose the option 8 to see how it work.
And please go to Settings>About machine and provide the following version information:
CanBus was 8, set to NO, apply, reboot, set back to 08, apply, reboot and it doesn't work.
Is below picture fine?
@Mcgyver83 If possible to share the order details to us?Included the order ID.
Order SP-DA2538
@Support Dasaita, which one should I download?
I see 2 link in your message.
I really appreciate the support you provide but it's a little bit annoying to reset the head unit each time.
I know that it's a complex software but take time to re-install and re-configure all apps. 😅
@Mcgyver83 Sorry for the confusion.
This one.
@Support Dasaita No luck.
It still not working.
Same issue described in messages that started this thread.
In the dedicate setting page, if I press "Mode", phone up, phone down, mic I see the highlighted command on the screen but nothing happens when pressin vol +/- or seek next / prev.
I tried to attach screenshot but the forum says something about "approval"
I jut got that there is a dedicate SWC section in the forum:
Forum > Aftersales Support > Technical Supports > SWC (Steering Wheel Control) associated issue
Should I open a new thread into this section instead of continuing here?
@Support Dasaita I already did what you requested.
When I'm in the SWC study nothing happens when I press vol +/- or seek next / prev.
Instead pressing mic, phone up, phone down makes highlighted (yellow square) the related icon on the screen.
Also "Mode" that is in the middle of the rudder is working fine.
I have a Toyota C-HR 2018, Italian.
The issue started when I update with a firmware provided via mail by the support to fix Android Auto/car play issue.
@Support Dasaita yes, if you check pictures above, there is a screenshot where I show "CAN key" as selected value.
Despite this, swc up/down/left/right buttons from left wheel rudder don't work.
Mode, phone up/down and mic yes.
@Mcgyver83 after switch to CAN Key,it can't program via the steps?
@Support Dasaita my setting is "CAN key" but when I enter the app to configure SWC, if I press volume +/- and prev/next nothing is highlighted on the screen. If I press mode,mic,phone up/down I see yellow square on the screen.
This behavior is shown in pictures in 2nd post of this thread.
