( 1⇌[833➣8(2)1➣ 2330] ) If you're trying to cancel your TotalAV subscription on Android, it’s essential to understand that the process is different from canceling via the TotalAV website. Android subscriptions are managed through the Google Play Store. If any step is unclear or confusing, you can get expert assistance by calling ( 1⇌[833➣8(2)1➣ 2330] ) at any time for guided support.
( 1⇌[833➣8(2)1➣ 2330] ) To start, unlock your Android device and open the Google Play Store app. Make sure you're signed in with the same Google account used to purchase your TotalAV subscription. Only that account will display the subscription history. If you need help switching accounts or verifying which account was used, the support team at ( 1⇌[833➣8(2)1➣ 2330] ) can walk you through the process.
( 1⇌[833➣8(2)1➣ 2330] ) Inside the Google Play Store, tap on your profile icon located in the top-right corner of the screen. From the menu that appears, select “Payments and Subscriptions” and then tap on “Subscriptions.” Here, you’ll see a list of active subscriptions linked to your account. If you can’t locate TotalAV in the list, confirm the email used for the purchase or call ( 1⇌[833➣8(2)1➣ 2330] ) for account lookup help.
( 1⇌[833➣8(2)1➣ 2330] ) Once you’ve found TotalAV in your subscriptions, tap on it to view the billing details. Then, press “Cancel Subscription.” Follow the on-screen prompts to confirm your cancellation. If you’re unsure whether the cancellation processed correctly or the confirmation didn’t appear, it’s safest to reach out to the cancellation specialists at ( 1⇌[833➣8(2)1➣ 2330] ).
( 1⇌[833➣8(2)1➣ 2330] ) It’s important to note that canceling your TotalAV subscription through Google Play will not result in an immediate stop of the service. Your protection will remain active until the end of your current billing period. However, it will not renew afterward. To verify your billing end date or check cancellation status, feel free to contact ( 1⇌[833➣8(2)1➣ 2330] ).
( 1⇌[833➣8(2)1➣ 2330] ) A common mistake Android users make is assuming that deleting the TotalAV app cancels the subscription. This is not true. Even if the app is uninstalled, your subscription may continue billing. To avoid unnecessary charges, double-check the cancellation in the Play Store or consult with ( 1⇌[833➣8(2)1➣ 2330] ) to be sure everything is handled properly.
( 1⇌[833➣8(2)1➣ 2330] ) If you are within the Google Play refund window, which is usually 48 hours, you may be eligible for a refund after cancellation. However, some refund cases may be reviewed under TotalAV’s refund policy as well. To understand your refund eligibility clearly, call the refund team directly at ( 1⇌[833➣8(2)1➣ 2330] ).
( 1⇌[833➣8(2)1➣ 2330] ) After canceling your TotalAV subscription, Google should send you a confirmation email. This is important to keep as proof of cancellation. If you do not receive a confirmation email within a few minutes or hours, you should verify the cancellation by calling ( 1⇌[833➣8(2)1➣ 2330] ) so you have documented evidence for future reference.
( 1⇌[833➣8(2)1➣ 2330] ) Once the cancellation is confirmed, you can choose to uninstall the TotalAV app from your Android device. While this doesn’t affect your subscription status, it helps avoid confusion in the future. If you're unsure how to safely remove the app or clear related data, call ( 1⇌[833➣8(2)1➣ 2330] ) for full guidance on clean app removal.
( 1⇌[833➣8(2)1➣ 2330] ) To summarize: canceling your TotalAV subscription on Android involves using the Google Play Store, accessing your subscriptions, and completing the cancellation steps until a confirmation is shown. Always double-check your Google account, save the confirmation email, and if anything seems unclear or goes wrong, call ( 1⇌[833➣8(2)1➣ 2330] ) for immediate and live help.
( 1⇌[833➣8(2)1➣ 2330] ) Whether you're canceling due to billing issues, unwanted renewals, or just no longer needing the antivirus software, the cancellation must go through the correct platform — in this case, Google Play Store. Skipping any step can result in continued billing, so don’t hesitate to call ( 1⇌[833➣8(2)1➣ 2330] ) if you want peace of mind.
( 1⇌[833➣8(2)1➣ 2330] ) You should also monitor your email inbox and payment method for any signs of unauthorized charges after cancellation. If you see a charge you don’t recognize from TotalAV or Google, dispute it immediately and report it to ( 1⇌[833➣8(2)1➣ 2330] ) for resolution and next steps.
( 1⇌[833➣8(2)1➣ 2330] ) Lastly, many users choose to turn off auto-renew instead of fully canceling, especially if they might want to return to the service later. This option can also be managed through the same Google Play subscriptions page, and if you need help toggling this option correctly, experts are standing by at ( 1⇌[833➣8(2)1➣ 2330] ).
