zlink/carplay crash repeatedly
    I was running an original PX6 u10 build and started having regular crashing as of ios26. I updated to the newest Max10 build today and regular crash/reconnect continues.
    Running Carplay/Zlink 5.3.49 and have been told 5.5.36 is the version to be running, but cannot find it anywhere.
    It that likely the problem, or would you have other suggestions? If it is the problem, can you provide that apk?
  • @dave w
  • Dave and I have a similar problem. When I upgraded my phone to the iphone 17 pro max and is now on ios 26, I had total disconnection with Zlink. So, I decided to upgrade my Desaita head unit running on PX6 Android 10 to the Max10 firmware. It was ok at first until it started to disconnect itself and this keeps on repeating. Is this a Zlink issue? Coz in my old firmware whenever I am using zlink my remedy is to just keep my connection through USB cable and not bluetooth. Now, both avenues are problematic with the disconnection issue.
    By the way, the zlink version now is V5.3.49.
    My Desaita is= PX6
    Android version= 10
    Android security patch level= May 5, 2020
    Build number= rk3399-userdebug 10 QQ2A.200305.004.A1 eng.hct.20200609.160238 test-keys
    Kernel Version= 4.19.111+   #1238 Tue Jun 9 15;48;02 CST 2020
    MCU version= MTCE_HA_V3.56_2 Jun 17 2020 13:27:56
    CPU= Dual-Core Cortex-A72@ 1.8G Quad-core Cortex-A53@ 1.5G
    HELP!
  • @LanceLLL
    System Firmware-MAX10-20230302:
    https://www.dropbox.com/scl/fi/mwzw2q4ojdfoz3mnp0i08/update.zip?rlkey=np70fog84q4mmy903xsofdz13&st=znaujgwo&dl=0
    Format USB drive to FAT32 Format.
    Copy the file update.zip” to the root directory of USB drive.
  • Ok. I will give this a shot although this is exactly what I did the last time. LOL!
    Is it not a Zlink issue? Maybe the Zlink is the one that needs fixing?
  • It's even worse now! Zlink could not even stay linked for 10 seconds. The Zlink version that came with the Max 10 is V5.3.38 just for your information.
    Also, I tried connecting to wi-fi and that won't even stay on for some reason and it keeps shutting off. Why is the tethering defaulted to ON when this thing is not even capable of sending out signal on it's own? This software is flawed. My android unit is basically useless coz I'm so dependent using it with my phone connected  to carplay all the time. I'm so frustrated right now.
  • @LanceLLL
    To be honest, MAX10 stopped releasing new software two years ago.
    The file we sent you is already the latest available version.
    If possible, could you please try to update Vivid10 which can support IOS 26?
    System Firmware-Vivid10-20250401:
    I think I'm totally screwed now! So I installed that firmware you sent above, started on the install process for SCOUT, I clicked the User Agreement, connected to my wi-fi as instructed, now I'm stuck on this screen for almost an hour now as I send this message and it's not going anywhere!!! What now???
    Stuck screen
  • @Support Dasaita so i've had a similar issue. i used to be on zlink version; 3.5.57. i have a px6 that came with max10 software when it shipped to me a few years back. the issue more recently is that i got a new phone and on the old version of zlink the headunits wifi would connect to my iphone and it would trick my iphone into using the headunits wifi which didn't work because it's not connected to a network.
    so basically i was told by dasiata support to upgrade to vivid10.
    this was a major mistake. i have the iphone air and before the extend of teh issue was that wifi issue and i could usually fix it.
    but this new version is so unstable neither wired nor wireless carplay work properly.
    we need access to all of the max10 and vivid10 software 'updates' so that we can test them out and see which ones are more stable.
    if anyone has a stable px6 software that consistently works with both wired and wireless carplay please send, we need your help!
    and dasiata support, please send us older version of the max10 and vivid10 software.
    OR give us the option to update only Zlink to the most stable version so we don't continue to have issues.
    thanks.
  • @LanceLLL
    In order to avoid the poor network causes this issue, please try to connect other phone/home WiFi to test if it can be activated successfully.
  • @CapacityDOGE
    Go Settings > About Machine, the send below pictures: Build Number.
    I did both home wifi and cellphone hotspot and it's not budging.
  • @LanceLLL
    Please try to use a Pin/Paperclip to press and hold the RST Button for 15 seconds to enter the recovery interface to do the factory reset.
    If no luck, please revert back to original MAX10.
  • Successfully installed Vivid10 with scout. Again, zlink disengages Carplay connection similar to the Max10 firmware.😞
  • This is after installation of the Vivid10. The ZLink connection is unstable again with frequent disconnections. The head unit is now rendered useless as I am so dependent on carplay.
    scout
  • Hello.
    Please try to do as follows to see how it goes.
    1. Re-pair your phone's Bluetooth with the head unit.
    2. Enable CarPlay on your head unit.
    3. On your phone, turn on Wi-Fi and search for your head unit's hotspot (e.g., "Android-***") to connect.
    4. Go back to the CarPlay interface, it should connect automatically.
    All of your instructions were followed to the dot. Carplay does connect automatically but it also "automatically" disconnects! It's so frustrating! I am so upset at this point that I am forced to have to buy another head unit. Guess what, Desaita won't be my next choice.
  • @LanceLLL
    We deeply regret the inconvenience and frustration this has caused.
    Your situation has been shared with our product and engineering teams to analyze and prevent similar issues in the future.
    Also, we appreciate the time and effort you have invested in communicating with us.
  • @Support Dasaita Hi, I'm having the same issue. I started having these issues after getting the iPhone 17 when everything was fine before with iPhone 16. It randomly disconnects so I can't use it.
    Any news on the fix? I also have the VIVID and most updated version.
    Thank you.
